Re: 44 Farmall H engine questions
Posted by Dellbertt on August 08, 2005 at 06:51:27 from (204.39.211.18):
In Reply to: 44 Farmall H engine questions posted by Chad from Michigan on August 08, 2005 at 04:16:17:
Drain the fuel, remove the sediment bowl and clean the tank. Blow out all the junk. Clean the sediment bowl. Install a screen in the top of the sediment bowl where it goes into the tank. That should eliminate any fuel supply issue. Make sure the float in the carb is not sticking and is adjusted. Make sure the plug wires are installed properly. I think the sediment bowl screen will do the trick.
Post a Followup
