Re: H Starting Problem
Posted by Bob M on August 08, 2005 at 06:59:19 from (151.190.254.107):
In Reply to: Re: H Starting Problem posted by RandyMcc on August 07, 2005 at 16:29:06:
It's possible the problem's a vacuum leak meaning draw enough fuel at cranking speed to fire. If that's the case using the choke (or giving it a whiff of ether) while cranking should cause it to start.
However my money's still on the magneto. Pull the center wire out of the mag cap, stick a good plug on it then crank the engine and see what kind of spark it throws. A lazy yellow (or no) spark says the magneto's causing your starting problems!
Post a Followup
