Re: charging
Posted by Wayne Swenson on August 08, 2005 at 14:38:53 from (66.191.69.100):
In Reply to: charging posted by matt lobdell on August 08, 2005 at 11:28:19:
Put a voltmeter on the battery posts; increase the engine speed and see if the voltage increases.
A fully charged 6 volt battery should read 6.3 volts and charge at 7 volts or so. A fully charged 12 volt battery should read 12.6 volts and charge around 14.0 or so.
Post a Followup
