Re: 6V generator/regulator woes
Posted by georgia Boy on August 08, 2005 at 19:54:07 from (66.168.213.124):
In Reply to: Re: 6V generator/regulator woes posted by John T on August 08, 2005 at 18:53:54:
That's the way I have it, if I understand your message correctly. I
have BAT on VR wired to the load side of the ammeter and there
is nothing connecting the generator or regulator to the field
resistor on that switch, that wire is just left loose and tape up. I
have the regulator and generator wired together as you indicate.
I'm baffled. I will check the grounding a little more closely when I
get in from work tomorrow. Thanks.
Post a Followup
