Re: Farmall Super C Timing
Posted by El Toro on August 09, 2005 at 11:10:14 from (205.188.117.73):
In Reply to: Farmall Super C Timing posted by Barry Huff on August 09, 2005 at 09:58:13:
Since you have that timing light I would use it.
Hook your light to the battery and plug lead to No1 plug near the radiator. Start the engine and let it warm up for a few minutes, then let it idle. Set your brakes and align DC1-4 mark with the little metal tab on the clutch housing cover.
If this is off you will need to move the distributor or mag to align the flywheel timing mark with the tab. I would chalk that timing mark on the flywheel to view it better. Hal
Post a Followup
