Re: 574 lo rev shifter fork replace
Posted by JB2 on August 09, 2005 at 19:17:08 from (69.196.154.214):
In Reply to: 574 lo rev shifter fork replace posted by mister irving on August 09, 2005 at 18:30:54:
Hi Irving, Bernard le mécano of Québec Canada, gave a method of going inside the transmission case thru the hole where the MCV valve is bolted on. His reply is posted about 5 pages down.
JB2
Post a Followup
