Re: Switching from non-detergent engine oils
Posted by EricB on August 10, 2005 at 05:02:56 from (216.209.84.11):
In Reply to: Switching from non-detergent engine oils posted by Kiernan3 on August 10, 2005 at 04:10:35:
Kiernan:
DO NOT DO IT!
Once you start using non-detergent it is very hard to turn back.There will be sludge that gets loosened up. The problem is not that it gets into your pan; the problem is it clogs all the lube ports in your bearings and inside the engine block. Think of it like colesterol in your veins. If it stays stuck to the artery wall its no problem. If it comes loose all hell breaks loose. (depending on the life you lead)
I used to race cars and we always used non-detergent. I believe that it provides better lubrication in the long run.
Post a Followup
