Re: Switching from non-detergent engine oils
Posted by Robert Cornell on August 10, 2005 at 05:52:17 from (209.62.168.161):
In Reply to: Switching from non-detergent engine oils posted by Kiernan3 on August 10, 2005 at 04:10:35:
If you switch to non detergent, I would suggest getting on a much shorter oil change rotation. The purpose of the detergent in the oil is to keep particles in suspension. This works great with a motor that has a positive pressure filter lubrication system as the suspended particles are filtered out of the oil. Older tractors have bypass filtration where only some of the oil is filtered. As noted in other replies, the non detergent oil allowed the sludge to settle out of the oil into the bottom of the pan. Remove the pan, clean well to remove sludge. Run the engine with some cheap detergent oil and one quart of fuel oil for a short time and drain. Use your detergent oil, but definitely decrease the amount of time between changes.
Post a Followup
