Farmall A Engine
Posted by Ted Womack on August 10, 2005 at 20:16:06 from (64.12.117.13):
I have Farmall A engine that is going on E-bay. It is in very good condition. Checked compression, wet and dry. Needs carb, but it is in 1st. class condition. It is still in tractor. Radiator is also going on e-bay. Had check at shop. Shows to be in good condition.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
