Re: Engine stuck
Posted by Karl Hamson on August 12, 2005 at 09:00:24 from (139.142.99.29):
In Reply to: Re: Engine stuck posted by Dellbertt on August 11, 2005 at 16:51:12:
One trick I have used is to put kerosene or similar into the spark plug holes, then drop the oil pan, jack up the tractor a bit and place a sturdy piece of wood between the ground or floor and a crank throw that is close to right angles to the floor. Let the pressure off the jack so the weight of the tractor is on the crank throw. After a few days if the tractor has come down the motor has turned a bit.
Post a Followup
