Re: Cheap Fuel
Posted by T_Bone on August 13, 2005 at 04:30:00 from (4.240.42.148):
In Reply to: Re: Cheap Fuel posted by Yugrotcart( from Japan) on August 12, 2005 at 20:32:12:
Hi Yugrotcart,
Quotes from my combustion engineer handbook:
Distillate oil= oil separated from crude oil by fractional distillation.
Diesel fuel= a distillate oil very simular to #2 fuel oil.
Kerosene= a light liquid petroleum fuel, a constituent in #1 and #2 fuel oils.
(end quote)
If you look at the properites of #2 distillate oil and #2diesel, there almost identical.
If you look at the properites of #1 distillate oil, #1diesel and kerosene, there almost identical.
Diesel engines don't know the different between #2 distillate or #2diesel fuel, nor do they know the difference between #1 distillate or kerosene or #1diesel.
So why have the different fuel types? Because a controlled combustion processes that use a metering orifice for fuel and oxygen can tell the difference.
My only concern would be how much gasoline does the diesel contain? Known mixtures of 20%gasoline with #2D work well in a IDI diesel engine without any problems.
I would think you could use a paint viscosity filter paper and compare to a known sample of #2D to find approx how much gasoline the diesel contains and use filtered motor oil to adjust for the viscosity difference.
T_Bone
Post a Followup
