Re: o t trailer brakes
Posted by Janicholson on August 13, 2005 at 21:03:07 from (66.173.50.8):
In Reply to: o t trailer brakes posted by in sticks on August 13, 2005 at 07:48:43:
Servo action in shoe brakes is the issue. This is the force on the shoes caused by the shoes themselves wraping into the curve of the drum. The leading shoe is always found by noting the forward direction of rotation (CW on right side, CCW on left), and the fixed anchor point of the assembly. in almost every case it is in the same location as the wheel cylinder. This fixed post takes the push of both shoes. The leading shoe will be the shorter length of lining. Taking the left wheel (drivers side) and with the fixed post and cylinder at the top, the leading shoe will be on the left (towards the front of the trailer). This shoe pushes on the secondary, or trailing shoe with the combined hydraulic or electric pressure) and its own servo force. the larger secondary shoe is longer so that even with more force on it they both wear about the same, and heat about the same.
I hope this helps. Jim Nicholson
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
