Re: IH 986 adjustments
Posted by Sheepdog on August 14, 2005 at 20:36:55 from (67.0.14.244):
In Reply to: IH 986 adjustments posted by slim51015 on August 14, 2005 at 18:47:46:
Going by the seat of my pants here, so if someone has better info tell him. Take the left lite off of left corner of cab (black painted piece lite fits in). You'll see an adjustment bolt pointing forward. Has a screw driver slot in it. A 1/2 wrench will lossen clamp around bolt. With tractor shut off push in clutch pedal, 1" or 1 1/2" of free travel should be where clutch pedal touchs under side of dash. Not sure which way to turn adjusting bolt, you'll figure it out. Tighen clamp when done. Now go to the right side of center section and linkage is there for trany brake. The pin towrds the back has a hair pin clip in it. Take the round pin out of clevis. Have someone push in the clutch pedal to the floor, tractor running. Move arm that comes out of bottom cover same direction as clevis (That pushes brake pad against a gear in the trany). Adjust clevis so when you line up holes in clevis and arm, the clevis holes go 1/4 farther than the arm hole. That will give it a preload on the gear. When you shift these tractors, step in clutch only enough to disengage clutch, wait for tractor to stop moving, then step in more if gears still grinding. If you step in all the way right away it wears out trany brake pad faster. The TA has a chorme shaft right behind this clutch adjusting rod. On this chrome shaft is a snapring. When the TA lever is moved on the dash the valve will go up and down. The snap ring should just touch the MCV housing when down and have a measurment of 1 9/64" when up. Move cable adjustment on the fire wall to get these measurements. You asked for detail. Sorry if I bored someone. Good luck.
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
