Re: 300U cooling problem
Posted by Janicholson on August 15, 2005 at 14:48:25 from (199.17.6.175):
In Reply to: 300U cooling problem posted by 300Randy on August 15, 2005 at 06:26:00:
The lower hose comes from the radiator, not the pump. It is a suction hose from the rad. It should be very warm (but below thermostat temp). If you disconnect the hoses from the engine (when cool) and plug the top radiator hose (a jelly lid or such clamped into the hose), while leaving the bottom open to the ground (or a big pan if you are inside), you can tell if the core is plugged as follows: Time how long it takes to fill a five gallon bucket using your garden hose. If it takes two minutes or less there is enough flow to check the radiator. If longer, you will need to use a bucket into an open funnel to get enough volume. If the radiator can take all of the hose flow without backing up, it should be ok. if not, it is clogged. (I have seen a water pump that spun the impeller on the shaft, but only one!) Another way to test is to install another radiator our of some other vehicle (it is ugly, but you do not have to go any where) and see if it solves the problem. Good luck, Jim Nicholson
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
