Re: differences between H and M tractors
Posted by larry dw on August 16, 2005 at 08:26:20 from (63.165.129.137):
In Reply to: Re: differences between H and M tractors posted by Allan in NE on August 16, 2005 at 08:12:19:
I'm learning a lot as I go along. Don't know anything about the underslung mounts. Is that something hard to modify?
I measured my 560 and the rear axles extend beyond the sides of the frame of the sweep (If I remember right the ends of axles tip to tip measures 8' 2" and the frame around 7' 8"). It seems like I'd have to remove a front bar at the ends of the front of the lift to spread the cylinders and bracing enough to back into place. I'm not sure if I'd have enough play in the cylinder and frame connections to do that.
I'd also have to slide the back wheels in as far as they could go to clear the frame. It would be darn snug!
Post a Followup
