Re: stuck head studs on M - help
Posted by El Toro on August 16, 2005 at 14:15:27 from (64.12.117.13):
In Reply to: stuck head studs on M - help posted by Farmerbash on August 16, 2005 at 12:57:47:
If the threads are good on the studs, I would leave them in the block. Just be careful with the block. I've double nutted stud's and applied some heat. They may have used locite
when these were installed. Hal
Post a Followup
