Re: HOT COIL
Posted by RayP(MI) on August 17, 2005 at 18:17:34 from (64.25.199.4):
In Reply to: Re: HOT COIL posted by Clint S on August 17, 2005 at 17:50:57:
Using a 12v coil and no resistor on my 200 - works fine. Hot coil may mean that it is shorted, or damaged. Otherwise check out rest of ignition system. Plugs, points, condensor, rotor, dist. cap. You should not need a resistor if you have a 12v coil in a 12v system.
Post a Followup
