Re: 756 bull pinion
Posted by K.B.-826 on August 17, 2005 at 21:36:42 from (68.115.85.231):
In Reply to: 756 bull pinion posted by MN Scott on August 17, 2005 at 21:08:54:
Depends if it's a early or late model. Early models can't be adjusted without removing the final drive. The manual says that if they rotate without any excessive binding or endplay, they're fine. If the endplay seems excessive, remove one .007" shim and re-check. Late models can be adjusted after removing just the brake, but it's kind of hard to describe the procedure. The way I read it, there should be no more than .007" endplay on a early model and zero endplay on a late model. You'll never get the brake seals to hold with loose bull pinion bearings.
Post a Followup
