Re: adding alternator to 460 Diesel
Posted by Bob M on August 19, 2005 at 04:41:25 from (151.190.254.108):
In Reply to: adding alternator to 460 Diesel posted by mark h on August 18, 2005 at 22:29:12:
Mark - can't give specific advice on mounting at 10 SI onto a 460. However on most conversions you can modify (bend) the existing generator tension bracket to work with an alternator.
The only difference between 1 wire and 3 wire Delco alternators is the internal regulator. Consequently you can buy a 3-wire regulator and install it convert a 1-wire alternator to a 3-wire.
Swapping regulators on a 10 SI is relatively simple, and can be accomplished without removing the alternator from the engine. A new regulator is less than $10.
Post a Followup
