Re: Original on early C?
Posted by Haas on August 19, 2005 at 19:25:04 from (12.65.12.187):
In Reply to: Original on early C? posted by leon on August 19, 2005 at 08:03:45:
The three bolt covers over the brake drums are likely factory original. The shafts that stick out on some tractors are as others said for sproket drives for fertilizer and planter attachments. These shafts are not part of the brake drums or the differential shafts. They are just bolted on to the brake drums and then another cover with a hole is put in place to accomodate the shaft. The right angle distributor is probably an aftermarket item.
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
