Re: M clutch replacement
Posted by Janicholson on April 07, 2009 at 06:13:05 from (199.17.6.128):
In Reply to: M clutch replacement posted by Dan Crocker on April 07, 2009 at 04:21:12:
The disk and PP can be removed W/O splitting.
Remove the belly pump, Remove the Coupling to the trans input shaft, If the PP has three bolt holes in the rearward facing surface at each lever, remove three (120 apart) bolts from the PP to FW, and put them in these holes. This compresses the clutch allowing fredom of motion.
Pull out the clutch shaft (it does come out!!)
and remove the PP and disk. Note the direction of the disk!!
The only issue is that the FW cannot be refaced while in the tractor, so if it is deeply scored, it will need to be split to machine it. Tiny scoring that is barely able to be felt with a fingernail is OK. JimN
