Re: Scwartz Wide Fronts
Posted by riverbend on August 20, 2005 at 21:45:19 from (208.160.33.16):
In Reply to: Scwartz Wide Fronts posted by GordoSD on August 20, 2005 at 21:09:48:
Do you mean the inner wheel bearing ? I have a Schwartz wide front on my H and could pull the wheel off and look, if that is the one you mean.
The OD of the spindle where in inner wheel bearing mounts is 1 3/8". There is a serial number or ID plate on the left side mounting angle iron that starts out IHC H... .
Post a Followup
