Re: tractor vet
Posted by El Toro on August 21, 2005 at 06:54:21 from (152.163.101.13):
In Reply to: tractor vet posted by whtpark01 on August 21, 2005 at 06:34:30:
Your rings may be worn or are stuck in the ring lans ( grooves) from all that black soot. Worn valve guides can cause oil consumption too. Those sleeves should be measured for wear, since you have it apart. Did that engine appear to be running too rich? Too much gas may have been removing your oil that lubes your sleeves. Hal
Post a Followup
