Re: Cub battery backwards
Posted by CNKS on August 21, 2005 at 15:00:06 from (204.249.178.138):
In Reply to: Cub battery backwards posted by Cubmaster on August 21, 2005 at 14:11:09:
Voltage regulator possibly bad, battery likely bad. Even hooked up wrong, the battery will last a long time. Bigger cables will help also. You need to polarize the generator --use a wire and briefly hold one end on the "Bat" terminal of the regulator touch the other end to the "A" terminal of the generator, you should get a spark, that's it. Your tractor does not care whether it is positive are negative ground, but a factory-type voltage regulator will not last as long if you use negative ground.
Post a Followup
