Re: 51 Farmall H problem
Posted by CNKS on August 22, 2005 at 08:21:01 from (204.249.178.138):
In Reply to: 51 Farmall H problem posted by Scott Jr on August 22, 2005 at 08:01:39:
Crud in the bottom of the gas tank got stirred up when new gas was put in the empty tank. First try cleaning the sediment bowl and screen, make sure there is nothing in the outlet of the tank. Disconnect the fuel line at the carb, and remove the carb fitting it screws into and clean the screen. If that doesn't help you are going to have to clean the carb. As a last resort, one that may or may not be necessary for lasting results, you can clean the tank.
Post a Followup
