Re: control valve leak ( slow)
Posted by Dave in CT on August 24, 2005 at 10:13:52 from (4.245.203.214):
In Reply to: control valve leak ( slow) posted by marvin on August 24, 2005 at 05:44:33:
I just recently found an easy fix to a hyd leak I had on my H. Drips from the bottom of the lift-all pump led me to clean everything off. After that I engaged the pump briefly, shut everything off and got underneath with a flashlight. Saw the leak was coming from where the brake-pedal side hyd port pipe screws into the casting of the pump. Pulled the pipe and put on some teflon tape, screwed it back in tight and have been leak-free for some time now.
You need to clean everything off and tell us where the leaks are originating from and, as the other post says, on what model and year of tractor.
Post a Followup
