Re: sterring box
Posted by Hobo,NC on August 24, 2005 at 17:38:45 from (151.213.83.22):
In Reply to: sterring box posted by andrews on August 24, 2005 at 12:26:54:
Thanks stan2270, hears sum info i have picked up from this board and tips I have saved, There are no adjustments on this steering gear. All you can do is make sure that everything is as tight as you can get it and then you will need to start replacing bearings and bushings. The good news is that new bearings and bushings where needed will usually tighten these up enough to be satisfactory. Rarely is the worm gear or worm wheel worn enough to need that expensive replacement unless you are really particular. After tightening and checking keys , next thing is to take the big plug out of front of steering gear and check the ball bearing on the end of the steering wheel/worm gear shaft. Shaft and worm are all one piece and ball bearing is clamped to end with castle nut. Any play in bearing or in clamping system will result in play in steering. You can also check by pulling/pushing on steering wheel. If there is any back and forth play, the bearing on the end of the shaft is likely bad or loose. Inner race must be tight to the worm gear shaft and outer race must be tightly clamped to the steering gear housing by the big hex head plug. Sometimes you have to put a washer under the plug to get it to tighten up, but be sure the washer does not also tighten against any of the other bearing parts or the bearing inner race. Most of these I rebuild have 1/2 turn play in the wheel and hard to steer. i shoot for 1/4 turn free play in the wheel and easy to steer. If the bolt holes in the axle assy are oboblonged I weld them up and re drill, worn holes and bent bolts will throw the caster off enough to cause hard steer'n. if i could tell for sure this is the magic bullet to fix steer'n problems I would'int have to git my hands dirty enny more. you are gonna havta take a look. I have had good luck with this kit but always find sumin else worn, most of the time its just a matter of tightening up thinks are replacing the keys etc. most sectors are reused. You kin rebuild it on the tractor but enny way you go you will need to remove the front axle. Remove the steer地 wheel and then the big nut/cap on the end of the steer地 box and the whole steer地 shaft will slide out. Remove six bolts that hold the steer地 bolster and remove, it comes out the bottom. Then you kin remove the pitman arm and sector for bear地 , seal & bush地 replacement. No mater what the bush地s look like replace弾m. If the steer地 shaft is bent and most are they are no problem to straiten out. You will need access to a press to straiten it.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I知 handing him tools and he says, "give me that..." and I致e already got it in his hand or "hand me that....."and I致e got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
