Re: 544 leaking oil from exhaust
Posted by JB2 on August 25, 2005 at 19:24:21 from (69.196.154.214):
In Reply to: 544 leaking oil from exhaust posted by Chris in Washington on August 25, 2005 at 11:37:22:
Hi Chris, I believe the 544 has a German D239 the same as 674 and 684. My brother has a 684 and when he uses it on a wood splitter where it is basically running at a fast idle, to prevent the slobbering, he does not put the STOP/RUN control lever all the way to the maximum RUN position. On a Bosch fuel injection pump the amount of fuel injected is controlled by the limit of the STOP/RUN adjustment. So by not putting the STOP/RUN to the maximum RUN position the injection pump is pumping less fuel into to each cylinder so it will burn clean and not slobber.
It doesn't take much just 1/4" less than maximum.
Give it a try.
JB2
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
