Re: Super C ,will not stop with switch ?
Posted by John T on August 26, 2005 at 08:24:55 from (66.244.90.98):
In Reply to: Super C ,will not stop with switch ? posted by Joe on August 26, 2005 at 06:32:50:
Joe, I gotta agree with Nat. It must be EITHER the switch went bonkers or its not wired correct or its not grounded.
1) If its a battery powered coil ignition it will run the battery down and overheat the coil left setting ON like that. A switch for a coil ignition ought to have a BAT input terminal fed from the battery maybe off the ammeters load (NOT to battery) terminal via the starter switch post etc. and an IGN terminal thats hot when switched to ON
2) If its a Magneto ignition it wont bother the battery and the problem is EITHER the switch is bad,,,,,,,,or miswired,,,,,,,,,or the switch may not be getting a good ground !!!!!!!! A mag kill switch works by dead grounding the points, so the switch needs a good wire up from the mag to the switch plus a good switch THAT HAS A GROUND CONNECTION.
John T Nordhoff in Indiana, retired electrical engineer
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
