Re: Question on LiftAll
Posted by Allan in NE on August 28, 2005 at 03:33:31 from (148.78.243.26):
In Reply to: Question on LiftAll posted by Trikeman89 on August 27, 2005 at 21:26:17:
Hi Trike,
When these old tractors came out, there were no such thing as "quick couplers" and the hoses usually stayed with your cylinders. Just remove the pipe plug and insert the hose between the street El on the tractor and your cylinder(s).
You can buy standard 1/2" hose at any tractor outlet or auto parts store. They will even make 'em up to the length you require. It is easier to have one end equipped with a swivel fitting also.
That external "rear delay" gizmo was/is nothing more than a "restriction" fitting in the line and I don't know of anyone who actually used the silly things with the old Hs and Ms. However, you can still buy restrictors at any store who sells hydraulic supplies.
Allan
Post a Followup
