Re: Question on LiftAll
Posted by makin'hay on August 28, 2005 at 16:00:14 from (69.95.141.209):
In Reply to: Question on LiftAll posted by Trikeman89 on August 27, 2005 at 21:26:17:
i use 1/2 " hoses on my lift-alls. its much easier to pipe to rear of tractor and then have a quick coupler somewhere above pto. then a short hose from lift-all ram to quick coupler. as far as the delayed lift.....they are designed for a plow or other trailing equipment when you want the rear of the implement to raise a little later than the front. the oil will take the easiest path first, then go thru the restricted port. as far as that...that should be already on your belly pump. [that is what you have right ?] my dad used this on a 3 bottom plow when i was a kid. when he got to the end of a pass, the front of the plow would lift first and then the rear so the furrows were the same length. [somewhat] if you look on your pump, you will see 2 ports on one side and one on the other. they are designed for single acting cylinders with the port on the left front and the right side the pressure ports and the port on the left to the rear, the delayed port. good luck.
Post a Followup
