Sleeves
Posted by For Hugh MacKay from Jim on August 28, 2005 at 16:30:19 from (66.173.50.37):
A good machine shop will install sleeves in blocks of all types. I know of no engines that could not have dry sleeves put in. The primary use (and quite often done) is to repair an engine whos block is very rare, or more expensive to replace than sleeve. In some cases it is possible to sleeve an engine just to be able to use a good set of pistons. Shrink fit sleeves can be installed without a shoulder on top. Either by careful shrink fitting of a straight sleeve, or the bottoming of the sleeve on a ledge made during preparation boring for the sleeve. Either way the new sleeve is machined off flat at the deck (top of block) and seals against the head gasket. The only issue I know of is the marginal success found when trying to sleeve a cracked cylinder wall. The uneven pressure, cooling, and corrosion at the old crack cause problems. Machining the cylinder to waterjacket, and installing a "wet sleeve in an engine with cast in place cylinder walls is not done because the block depends on the compression strength of cylinder casting to resist internal forces and stress, including head bolt pressure. Works for my customers in the past, and on things from aluminum briggs blocks, to rare or one off jewels that would be junk without a sleeve. Ive never seen a sleeve fail (except in a cracked block. Good sleeve repair makes old better than new sometimes, metal used by reputable sleeve manufacturers, often wears longer than cast iron. Lots-0-life, Jim Nicholson
Home
| Forums
Today's Featured Article -
Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
