Re: Farmall H additional questions- Rearend/transm
Posted by riverbend on August 28, 2005 at 18:36:58 from (208.160.33.83):
In Reply to: Farmall H additional questions- Rearend/transmissi posted by DJL on August 28, 2005 at 17:28:08:
The rearend and tranny share the same fluid i.e. 90W gear oil. You will need about 6 gallons. There are two drain plugs. One is under the PTO, and (without looking) the other is underneith, near the front of the trans housing. If you look around, you'll see them. The fill plug is next to the steering column, and the level plug is about half way down on the left side, near the clutch pedal pivot.
The leak is probably coming from either the input shaft for the transmission or the drive shaft for the hydraulic pump. Or both. Both seals can be replaced from underneith the tractor.
Post a Followup
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
