Re: need help with a mag
Posted by El Toro on August 29, 2005 at 10:22:55 from (64.12.117.13):
In Reply to: need help with a mag posted by Paul G. in Mn on August 28, 2005 at 15:04:10:
Did you reinstall the mag with the rotor in the same position as when you removed it from the tractor? Can you get it to fire on the bench
by holding the coil wire within a 1/4" of good ground? You need to pull the coil wire from the
cap and snap the impulse coupling. Check that point gap too. Hal
Post a Followup
