Re: Front Wheel Bearings on Farmall M
Posted by Janicholson on August 29, 2005 at 11:32:26 from (199.17.6.70):
In Reply to: Re: Front Wheel Bearings on Farmall M posted by RustyFarmall on August 29, 2005 at 06:38:23:
If the wheel to hub (three bolts) are not an issue, Then the way you have described your bearings is a problem. The inner race shoild be a nice clean finger push onto the spindle. it should turn, but only with a fair grip on it. If the race is easy to spin, and has clearance, either it (not likely) or the spindle (likely) is worn. There should be no sholder to prevent its removal as indicated in your post. The hub should also have the outer race in a tight grip. This grip is a press fit and requires a driver, or patient careful punching around the edges to install, or remove it. Worn spindles and hubs could be repaired (welded up and re-bored to spec) but different parts may be cheaper. If it was used with a loader, and or the grease was never changed, the wear can be on the parts that are not hardened. New bearings are also probably a good idea, as these will be worn to some degree from "walking around" in the parts designed to hold them in place. I hope it is the wheel bolts. JimN
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
