Re: Power steering and Brakes
Posted by Aces on August 30, 2005 at 05:05:53 from (67.0.20.150):
In Reply to: Power steering and Brakes posted by John Y. on August 29, 2005 at 19:02:47:
John If you have a PTO and remote and hitch hydraulics then the drive splines at the clutch pressure plate should be ok, and hydraulic filter should ok. If not start with filter. If thoes things ok could be pump, could be stuck valve in the MCV valve.
Post a Followup
