Re: Amp meter
Posted by Bob M on August 30, 2005 at 06:17:04 from (151.190.254.107):
In Reply to: Amp meter posted by oleduke on August 30, 2005 at 05:55:29:
With a good battery, the engine running at governed speed and the lights off, ammeter should indicate approx 15 amps charge immediately after startup. It should then taper to 5 amps or so as the battery comes back up (usually takes several minutes).
3 - 4 amps discharge at low idle is normal.
Post a Followup
