Re: Amp meter
Posted by Janicholson on August 30, 2005 at 06:24:10 from (199.17.6.175):
In Reply to: Amp meter posted by oleduke on August 30, 2005 at 05:55:29:
Assuming a good system (with regulator, ___not___ a three brush, or cutout relay with charge rate settings on the light knob), that the battery has been used to start the tractor, and that it is running at 1/2 throttle. The amp meter should show about 12-15 amps charge for about 1-2 minutes then decrease from there to show 5 amp charge in 5 minutes or so. After about 15 min the charge should be about 2 amps (maybe 1 amp) and it should stay there till the engine is shut off. If the lights are turned on, the amp meter should spasm for a tenth of a second an the load is compensated for, and then settle back to the 1-2 amp charge rate. The amp meter only shows what is entering (charging), or leaving (discharging)the battery through all systems except the starter motor (which draws so much current that the meter would smoke if applied across it). The starter operates on a direct circuit (solenoid, or mechanical momentary contact heavy duty switch) Not all systems will appear this way to the meeter viewer, if it charges more than five amps all the time into the good battery it needs to be checked with a volt meter. Charge volts for 6 volt systems (into an already charged battery lights off) shaould be 6.8-7.2 volts. A 12v. should show 13.8-14.3 volts. I'd adjust any regulkator out of those ranges. Alternators are a different animal. Hope this helps, Jim Nicholson
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
