Re: Positive ground
Posted by Harold H on August 31, 2005 at 14:23:46 from (67.140.121.137):
In Reply to: Positive ground posted by Tyrod on August 31, 2005 at 08:34:15:
Generally, if it is 6 volt it should be positive ground and if it is 12 volt it should be negative ground.
Harold H
Post a Followup
