Re: finally something to work the Farmalls!!
Posted by Haas on August 31, 2005 at 18:20:48 from (12.65.78.26):
In Reply to: finally something to work the Farmalls!! posted by KevinH on August 30, 2005 at 18:21:08:
I doubt if the F-12 will be enough to pull your sawmill. At best you will be sawing real slow. As a youth, we had a small sawmill on our farm. It came from Sears and was actually made by Belsaw, I think. The MD was the tractor that pulled it. I recall once my Uncle belted the Super A up to the sawmill and was sawing. I came by a while later and the MD was back on the Mill. I asked what happened. He said that he wanted to see how the Super A would do with the sawmill. Evidently it wasn't enough, because as far as I know, the A was never hooked to the sawmill again.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
