Re: 826 vs Chisel Plow - Update (826 Won!)
Posted by 806man on August 31, 2005 at 19:04:03 from (66.38.101.2):
In Reply to: Re: 826 vs Chisel Plow - Update (826 Won!) posted by the tractor vet on August 31, 2005 at 18:34:23:
Nothing better that the sound of that old farmall strutting it's stuff!!! Put that chisel in the ground with a straight exhaust stack at night and you can really see the "red" glow... You will soon get use to the throttle lever being behind the steering wheel. You only need to use it to slow that "bad - boy" down!!!
Post a Followup
