Posted by Janicholson on April 07, 2009 at 09:42:39 from (199.17.6.128):
In Reply to: Re: Battery Drain posted by ScottyHOMEy on April 07, 2009 at 07:25:57:
Clearing up mud (letting it settle) The internals of the switch have two seperate parts, one is for charge control, the other is lights. They are on the same shaft, and in the same Molded plastic housing, but do not connect electrically. The light sw part has a D and B function which takes its supply from a wire going to the Amp meter load side. The D position connects this power to a resistor (on the switch), then to the light wire out put. The B position connects the same input to the light wire directly, no resistor.
(I would have put two bulbs or filiments in the bulbs and had the D control one, and the B control the other, much brighter than normal lamp, but I was not born then nor working for IH)
The Field control is (for sure) not connected to the power at all. It is "ground only" (through the switch internal bushing and mount to the Electrical box). This is direct to groung all the time when the H D and B positions of the Switch knob are selected. When in the L position (full CCW), the Field is grounded through a wire wound resistor (also mounted on the Switch). This resistor cuts the field current to about 13 of full output. #4 on bobs diagrams. (If I remember) JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
