Re: IHC 574
Posted by Jb2 on September 03, 2005 at 18:43:13 from (69.196.154.214):
In Reply to: IHC 574 posted by Gene Chernault on September 03, 2005 at 16:56:41:
Hi Gene, are you asking about the pressure sensed by the sensor under the seat that turns on the transmission warning light on the dash? I looked in the I&T shop manual for 684 which is same rear end as 574 and the only pressures it mentions are the hydraulic pressure for main pump is 12.5 gpm @ 1500-1600 psi, relief valve should limit to 2300 to 2500 psi. Pressure to PTO clutch should be set to 220 to 250 psi. Power steering is supplied by flow divider @ 2.5 gpm and 1500 to 1600 psi. There is a separate lube pump that supplies 4.5 gpm to lube the transmission and I believe this is the one that the pressure switch under the seat measures. The shop manual mentions this lube pump and says there is no way to check the flow as all oil passages are internal to the transmission. I do seem to recall that the switch under the seat had something like 10 PSI stamped on it. Maybe Bernard le mecano will assist you as he has worked on many of these tractors for IH dealer. Hope this helps JB2
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
