Re: Update on Tractor quit
Posted by farmallhal on September 05, 2005 at 07:08:14 from (64.24.35.16):
In Reply to: Update on Tractor quit posted by nc140mans on September 05, 2005 at 05:32:27:
I wonder if you have an intermittment problem with the push-pull switch. Next time it fails jump across the two lugs on the back and see if the ammeter moves to show a discharge without starting the tractor. El Toro mentioned the coil and condenser which could be candiates as well since it just stopped cold when running. Don't know what the ammeter would show if one of them would be open from a heat issue when the switch was pulled out. Good luck, Hal
Post a Followup
