Re: hotwire a farmall B
Posted by John T on September 05, 2005 at 10:43:50 from (66.244.90.98):
In Reply to: hotwire a farmall B posted by Rich Lorenz on September 05, 2005 at 10:17:10:
Rich, to "hot wire" the ignition you need a temporary hot ungrounded battery voltage feed to the coils input supply (NOT terminal to distributor) terminal. That simply does the job of an Ignition Switch. Use caution n have it so you could disconnect quicky if needed without dead shorting that hot wire to frame ground. A big cable such as a jumper cable could be used to jump the starter if needed.
John T
Post a Followup
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
