Re: 9 Speed trans. on an M ?
Posted by Brad in WI on September 05, 2005 at 14:02:58 from (24.208.23.46):
In Reply to: 9 Speed trans. on an M ? posted by Andy in Ohio on September 05, 2005 at 13:26:19:
From my experiences with the 9 speed trans. everything sounds ok. I believe what it does is splits 4th and 5th gear several times. Please correct me somebody if I am wrong. The value to have it depends on what you plan to do with the tractor. I am not sure about the engine though. Someone else should be able to help on that one.
Brad
Post a Followup
