Re: 350D not starting
Posted by Janicholson on September 07, 2005 at 09:59:01 from (199.17.6.175):
In Reply to: Re: 350D not starting posted by El Toro on September 07, 2005 at 09:29:12:
If there is no juce at the starter end of the big wire from the battery, the connection at the battery is bad, or the wire is corroded/broken internally. If the juce does not show on the starter side of the system then it is either the solenoid or the pushbutton/key. If the little wire going to the solenoid has voltage when the start button/key is pushed/turned, then the ign key/wires need to be gone over. To test solenoid Put in neutral, set brakes, jump with a 14 ga. wire between the solenoid terminal attached to the battery, and the small solenoid terminal. No crank, the solenoid is suspect, crank and it is the Key/button.
I hope this helps,
JimN
Post a Followup
