Re: C oil pressure problem
Posted by El Toro on September 07, 2005 at 14:19:26 from (64.12.117.13):
In Reply to: C oil pressure problem posted by Pete LaBelle on September 07, 2005 at 10:41:16:
You may need to check your rod and main bearing clearances. That tractor doesn't have cam bearings and there may be some wear in the cam bore too. You may want to look at that oil pump pickup screen for any restriction from sludge.
Hal
Post a Followup
