Re: Farmall Cub - Traction
Posted by CNKS on September 08, 2005 at 20:08:24 from (204.249.178.138):
In Reply to: Farmall Cub - Traction posted by Mr. Tibbs on September 08, 2005 at 18:45:10:
Old is correct. But, do you have the hitch set so that it floats? Your Cub has 2-way hydraulics (down pressure), I think. Very hard to regulate depth with down pressure on the blade, it needs to float. You simply cannot run it even moderately deep, the tractor does not have enough power, particularly with those small tires, and sand is the worst possible "soil" there is.
Post a Followup
