Re: Regulator Failures
Posted by the tractor vet on September 10, 2005 at 06:51:09 from (4.124.72.68):
In Reply to: Regulator Failures posted by NJRon on September 10, 2005 at 05:04:29:
Some times i have found that with tractors that set outside it is not the reg but the grounding problem and when you change the reg you just made a new ground so before you by a new reg. i would clean all grounds and see what happens and sometimes the points in the reg. get corroieded and it will not charge , i go thru this on the 720 JD about twice a year and about every other year we have to replace the reg.
Post a Followup
